Nice little dew controller kit
Started by Rocket Pooch, May 02, 2010, 20:59:00
PhilB
Quote from: Space Dog on May 09, 2010, 18:51:02
Have a look at the one I built last week, it only took about 30 minutes to do.
Chris, I'd rather like to see this. Did you post it?
Its here Phil, http://www.dewbuster.com/heaters/heaters.html one tip get a piece of wood put 4 nails in it 2 left 2 right spaced as per the spacing you want for the + & - pull the wire between the left and right sides and this gives you a nice template to solder the resisters onto.
For the insulation I use gaffer tape and double sided number plate tape (foamy stuff) the foamy tape on the outside.  The wire I used is nickle covered copper wire from maplis its solid and about 1mm thick.
The resisters I used are M330ohm from Maplin, they seems to have gone upto 17p each now, I'm positive they were 8p when I bought a load.
My 8" SCT tool 24 of these, some wire and a connector to the dew heater.
I used the same construction as Chris for two small tapes and they work a treat.  Whether you use resistors or Nichrome wire I'd strongly suggest you use very flexible cable so it stays like that in low temperatures.
PS. It's 330 ohm resistors....
Yeah don't use Maplins, they are at least 10 times more expensive than anywhere else.
PhilB
#36
Thanks everyone, I'll give building a heater strip a try. One point though, what type of connectors do you use when connecting the strip to the power supply?
however, if you use Maplins then they'll be there when you need something for a project, *right now*...
Male phono plugs are standard for the leads - yes I know.  Known for their superior current carrying capacity and reliable connection - not!!!
In other words, choose whatever connector you like. if you are making your own controller and strips then choose something suitable, you don't need to use the standard type connector.
I like Banana plugs myself. Nice and reliable.
Yellow banana plugs would match the scope nicely ...
Quotehowever, if you use Maplins then they'll be there when you need something for a project, *right now*...
RS is the same, they have direct access trade counters.
Quote from: RobertM
They would match my banana scope VERY nicely  :cheesy:
Ok, its probably £2 for a dew strip then, :-)
Thats means the controller and strip would probably be £13, bargain.  The cheapest pro made one I found for the controller was £29.00.
Home made rules..
