Finally !!!!
Started by Mike, Feb 27, 2010, 11:01:14
Now that is impressive...................
Very impressive  :o
Serious piece of kit, that. ;)
OK I have now ordered a replacement gear and worm set for my EQ6. Only thing is I have to wait for 2.5 months for them to be made and delivered !!!   :o
Well that was a lot quicker than he told me! My gears are now ready :D Woohoo !!!
A shop in Canada is also now stocking EQ6 and other skywatcher spares :-
http://www.kwtelescope.com/
New gear and worm arrived from Germany today. With a bit of luck i might have time before Friday to fit it to the mount.
:D
Shock! Horror !!   :surprised:
Fitted the new gear and worm tonight and after about a year hiatus my mount is now back up and (apparently) running fine. Not tested it with a load yet but slewing it seems fine and smooth with the new gears in. I am about to take everything out into the garden to give it a load test and see if it slews and tracks with a load. If everything is running fine then i'll be bringing it all along to the uDSC this weekend and (weather permitting) hopefully getting some images for the first time in about 2 years.   :D
That's great news Mike, the weather is looking really good so hopefully everything will come together for the w/e.
Cool - it'll be so good to see you imaging again!!
Test image. Clear filter. M57. 5 mins single frame. Binned 2x2. Rough focus just to test guiding. All seems fine after 5 mins. Though i'm getting amp glow like the cooler isn't on.
Overall - Chuffed :D
Is there a setting in MaximDL 5 that turns the cooler on and off on the SXV-H9? I never had amp glow using MaximDL 4.
I thought the cooler on the SXV cameras were on all the time.
No there isn't an option, the cooler is on all the time.
yay your up and running again
Quote from: RobertM on Jun 04, 2010, 09:59:46
Weird the image appears to be showing amp glow then.
