M42 and Rosette Nebula 12/12/09
Started by Daniel, Dec 15, 2009, 09:56:26
Hi Fay, I Use EOS utility for capture and live view focusing, Really easy to set up multiple exposures.
:O)
Does that come with the camera software?
Fay - Canon capture that comes with the cameras only allows max 30 second exposures.
So really, you just need to junk everything then get a C14 with Hyperstar   ;)
At least then when things go wrong you'll know in 30 seconds rather than 30 minutes  :lol:
With the 350D, the EOS Utility (supplied on CD with camera) only allows exposures up to a max of 30 seconds, so I use a separate shutter control program but let the EOS Utility auto-downlaod the raw images to a folder on my PC.
However, I may soon be moving completely over to Nebulosity since the latest release allows images to be saved to the CF card  (previously it would only download of images in a huge TIF, or was it FITS, format).
Nebulosity integrates with PhD to do inter-frame dithering - a big win, now I've got it working.
Mick don't tempt me!!!!!! You know how easily influenced I am :o
Mark I did download Nebulosity this week, a very good manual comes with it, very detailed
Eos utility on the newer cameras (400d and above i believe) will allow exposures as long as you like.
QuoteEos utility on the newer cameras (400d and above i believe) will allow exposures as long as you like
Fay, that's what's on the disk I gave you last night...
Thanks a lot Robert.
Is it obvious how you get it going?
QuoteIs it obvious how you get it going
For some reason, the way your lucks been going, I read that as
................ how to get it WRONG  :lol:
I have my doubts about the Canon utility taking longer exposures.  The version that came with my 400 would not control camera settings as you can do with the 350 so there is presumably a firmware change as well as hardware.
If the utility for the 450 is a different version it may work.
I am too bone idle to compare the 350/400 camera/software at the moment  ;)
The EOS Utility sofware that came with my Canon 450D does longer exposures, as the ones I did of M42 were 1 minute subs (using that software) and I am sure from the programming as it was set up 00.00 that you could do much longer subs than that.
Hmmm
I wonder if it's the software or the camera that does the long exposure  :-?
I'll have to check to see if there's a software update at Canon.
The software allows up to 99 hrs I believe and I can't imagine Canon has done anything else other than just extend the 30s limit.
QuoteIs it obvious how you get it going?
Relatively...
