Upcoming DSC...
Started by JohnP, Nov 02, 2009, 10:08:11
Hi all,
This is the website for the campervan company which is based at the entrance to Blacklands.
Good Luck.
http://www.vwkampers.com/
£350 is a bit dearer than £10!
Is a lot but then they are expensive to buy and insure. Did you see the price of the second hand ones?
I was only thinking of using it in the field
It's worth giving them a call.
It's only going next door
You won't be putting any mileage on it
You won't be taking it on the road
It's out of season - only astronomers are daft enough to spend a weekend in a field in November
Yeah they might let you have it a lot cheaper. It's worth a try.
Have sent them a mail
Had a reply from camper van. For 3 nights £100
Bargain.................
Bit different from £350
Oooh Luxury  ;)
So it will work out at about £40 a night with an electric hook up
I'm guessing it's a 2 berth - that would be nicely comfortable for you and your kit - and dry - and warm   :)
2 berth means 2 VERY friendly people or one and a puppy  ;)
It's worth it just to try it out
I am thinking this weekend may be off, what do you think?
I am toying with the idea Mick, wonder if they are heated
I thought that sounded a little expensive to be honest. You'd get a b and b with breakfast for about that this time of year...
well it is £200 off Ian, although it would not be going anywhere. Not the same to go off site to sleep etc, best to stay with the group
I'll be going regardless, might even go on Thursday.
There's going to be at least one and a half decent nights so I can practice buggering stuff up with no distractions.
Probably heated. but even if not, the gas rings will work  ;)
Email them
Well, Mick,  If weather ok, I may  go thursday, but it is looking torrential.....at the moment
Quotelooking torrential.....at the moment
That's the benefit - no water running under the tent and nothing to put away wet and dry in the garden 2 weeks later  ;)
