Author Topic: Jupiter Movie  (Read 1413 times)
A.S.I.G.N_Baz
  • Non-OAS
  • Star Class
    • Barry Armstead Photography
Jupiter Movie
« on: Oct 11, 2008, 01:53:35 »
Hi all,
this is the culmination of a broken corrector plate, a couple of hours capture and a couple of days of processing.
Enjoy!
The movie is on the bottom of the page.
http://www.asignobservatory.com/astrophotography/image_gallery/planets.aspx
Cheers, Baz.
Re: Jupiter Movie
« Reply #1 on: Oct 12, 2008, 16:55:35 »
Baz,
Broken corrector plate?  That's simply terrible!  What on earth happened?  How did you repair it?
A.S.I.G.N_Baz
  • Non-OAS
  • Star Class
Re: Jupiter Movie
« Reply #2 on: Oct 13, 2008, 00:22:12 »
Baz,
I didn't. I am still waiting on quotes and info on replacing it as I beleive it has to be matched to the primary and secondary as a set. It may be worth buying a new socpe. It will never be top of the line again, but I was pleased with the results though. It's like running with a blister. Sure you can still run, but it hobbles you a bit.
The crack came from one of the screws holding the retaining ring on. Our winter this year was minus temps every night for a few weeks and I had a 20 degree spring day. It doesn't take a genius to see how it happened.
  • Observing Consultant
    • Electronicle
Re: Jupiter Movie
« Reply #3 on: Oct 13, 2008, 11:41:19 »
Ouch!!   :roll:
Re: Jupiter Movie
« Reply #4 on: Oct 13, 2008, 13:21:49 »
Baz,
Is that the scope you did all that hard work on - the Peltier cooling?  If so, you must be even more gutted.
Still, I reckon that crack would make very little difference to the final image except that it might disperse some extra light where you don't want it.  I might be wrong though ...
  • Administrator
Re: Jupiter Movie
« Reply #5 on: Oct 13, 2008, 16:16:32 »
It'll depend a bit how much the figure of the plate changed as a result of the stresses relieved when the plate cracked, I guess...
