Jupiter and Io
Started by MarkS, Jul 24, 2008, 01:51:34
Jupiter tonight using eyepiece projection on the Celestron C11 with the SPC900 webcam
400 frames at 0.2 sec stacked in Registax then deconvolution applied.
You never disappoint, Mark, really nice.
it is indeed, especially given Jupiter's altitude at the moment.
However, I'd say you've overcooked it a little on the deconvolution. Try applying a little less so that ringing disappears.
It's also good to see a moon in the same shot, you didn't cheat, by the look of it :)
Nice one Mark, it's a difficult to catch any shots of Jupiter at the moment and even more difficult to process something from the blur - an awful lot of atmospheric disturbance can happen in 0.2s !
Nice one Mark. As Ian says it is overcooked andf looks like 3 out of register images of Jupiter on top of each other. But well done for getting the moon in the same shot (presuming you didn't cheat).
Admittedly it is a bit overcooked - I was trying to extract as much detail as I could.
As for Io, there was no cheating!  I was pretty pleased to get it showing so well in the final image - before deconvolution it was just a faint blur.
go on, post a raw stack :D
Sure!  I'll do it tonight (after OAS).
Love the colour your showing on Io, is that 2 sets of exposures for moon and jaupiter or all in the same shot?
Daniel, Io and Jupiter are in the same shot - it's not a composite image.
Ian, as promised, raw stacked image of 400 frames at 0.2sec is here:
it's certainly a bit murky. Could you stick up a link to the raw BMP? I've just had a play and I can show some fantastic jpg artifacts :(
I'll post the 16bit tiff tomorrow then you can play with the full depth of data.
QuoteDaniel, Io and Jupiter are in the same shot - it's not a composite image.
I can't find Daniel in this image!!
I had to deconvolve the Jupiter raw stack with a Gaussian having standard deviation of 10 pixels or 1.3 arcsec, since an arcsec is around 7.5 pixels in this image.
So, roughly speaking, a star at similar altitude (15deg) would have an FWHM of around 20 pixels  (2.6 arcsec).  Indeed, using the Io as a proxy for a star, the FWHM of Io is definitely round about 20 pixels.
