Extra gallery albums...
Started by Rick, May 13, 2008, 21:29:53
I've created a new gallery category for Instruments and Data Files, which is a bit of a mix, but it seemed like a good idea at the time...
There are two public and two members-only albums in it. If you're not logged in to the gallery you'll only see two albums. If you are logged in then you'll see four...
...and I've now fixed it so that you can actually upload data files of the following additional types without it doing anything obstructive:
FITS - files with an extension of ".fit" or ".fits"
RAW - files with an extension of ".raw"
It won't bother trying to generate icons for these files.
It should also allow:
AVI - files with an extension of ".avi"
MOV - files with an extension of ".mov"
WMV - files with an extension of ".wmv"
but it may well attempt to run these for you.
doug
     Wow !!!!!!!!    Computerspeak or what, Rick ????   :o
     I only wish that I understood..... never mind, still learning. :-?
