ISS Prediction
Started by MarkS, May 10, 2008, 17:15:30
Bright passes (mag -2.0 and brighter) every single morning for the next week between 3-4:30am ...
http://www.heavens-above.com
On May 18/19 you can watch it go over 3 times in succession ...
In fact there is a magnitude -2.0 (or brighter) pass every single night from now until the beginning of June.
On the night of 21 May there are FIVE visible passes in succession and at that point it changes from being an early morning object to a evening object.
18-31 July 2008
There is a visible pass every evening at magnitude -2.0 or greater.
More info at http://www.heavens-above.com
Also some in the next few days if you're prepared to get up at oh-dark-silly o-clock to catch them a bit before sunrise...
Mind you are not insulting Mark there Rick!
#5
Satellite predictions with favourable viewing geometry (>25) for:
Ground Station    : High Elms, Farnborough, Kent, England   ---   JO01AI
Time Zone         : UTC (+0.00 h)
                           in eclipse *  in daylight o
Date       Rising at    Peak elevation      Setting    Height Satellite
Y M D  Time      Az.  Time      Az. El  Time      Az. (peak) Name
080723  21:37:53  261  21:42:38  277 86  21:47:38*  83        ISS
080723  23:13:05  279  23:17:50* 203 81  23:22:50* 104        ISS
080724  00:48:10  282  00:52:48* 210 25  00:57:33* 138        ISS
080724  20:26:23o 247  20:31:08o 168 61  20:36:08o  78        ISS
080724  22:01:27  272  22:06:20   13 81  22:11:13*  92        ISS
080724  23:36:39  283  23:41:25* 201 49  23:46:17* 120        ISS
080725  19:15:07o 229  19:19:45o 153 32  19:24:30o  77        ISS
080725  20:49:57  261  20:54:42  284 87  20:59:42*  83        ISS
080725  22:25:09  279  22:29:54  196 81  22:34:54* 104        ISS
080726  00:00:14  282  00:04:52* 209 25  00:09:30* 139        ISS
080726  19:38:27o 247  19:43:12o 163 61  19:48:05o  78        ISS
080726  21:13:31  272  21:18:24   28 80  21:23:17*  92        ISS
080726  22:48:43  283  22:53:29* 198 48  22:58:21* 120        ISS
Note: Those times are UTC, so you need to add an hour for BST.  :roll:
No prizes for guessing what the OAS will be doing shortly after 10pm [Edit: UTC] tomorrow night ...
Watched the pass earlier this evening. I wonder how easy it'd be to catch the daylight pass 20:26-20:36 UTC tomorrow? It's during the monthly OAS meeting... :)
080726  19:45:53o 249  19:50:46o 171 67  19:55:46o  78        ISS
080726  21:21:14  274  21:26:07  359 82  21:31:07*  93        ISS
080726  22:56:35  283  23:01:20* 204 45  23:06:21* 122        ISS
080727  18:36:55o 233  18:41:41o 155 38  18:46:34o  77        ISS
080727  20:12:01o 264  20:16:54o  19 85  20:21:55o  84        ISS
080727  21:47:22  281  21:52:15  182 75  21:57:16* 107        ISS
080728  19:02:49o 251  19:07:42o 160 71  19:12:42o  79        ISS
080728  20:38:10  275  20:43:03   32 83  20:48:03*  95        ISS
080728  22:13:24  283  22:18:17  200 42  22:23:10* 124        ISS
080729  17:53:44o 235  17:58:37o 153 41  18:03:30o  77        ISS
080729  19:28:58o 265  19:33:51o  31 82  19:38:51o  85        ISS
080729  21:04:11  281  21:09:04  205 72  21:14:12* 109        ISS
Stll some good high passes to come. 10:21pm tonight looks promising, and the 8:46pm daylight pass might just be near enough sunset for it to be visible. Did ISS boost its orbit recently? I notice this bunch of predictions are slightly later than the one from Tuesday.
22:06pm tonight (Tue 29 July) reaching max altitude of 70deg in the SSW ...
... better get my broom handle out.
#10
Today's calulations give this:
080729  17:53:24o 235  17:58:17o 153 40  18:03:10o  77        ISS
080729  19:28:38o 265  19:33:24o 321 83  19:38:31o  85        ISS
080729  21:03:51  281  21:08:44  202 72  21:13:45* 109        ISS
080730  18:19:15o 252  18:24:08o 164 74  18:29:09o  79        ISS
080730  19:54:36o 275  19:59:29o  29 84  20:04:29*  96        ISS
080730  21:29:50  283  21:34:43  201 39  21:39:36* 126        ISS
080731  17:10:08o 236  17:14:53o 156 43  17:19:46o  77        ISS
080731  18:45:14o 266  18:50:07o   2 83  18:55:07o  86        ISS
080731  20:20:34o 281  20:25:27o 187 69  20:30:28* 110        ISS
080801  17:35:51o 254  17:40:44o 174 77  17:45:45o  80        ISS
080801  19:11:12o 276  19:16:05o   6 86  19:21:05o  97        ISS
080801  20:46:33  283  20:51:18  203 37  20:56:11* 128        ISS
080802  16:26:43o 238  16:31:29o 157 46  16:36:22o  77        ISS
080802  18:01:49o 267  18:06:42o 358 82  18:11:43o  87        ISS
080802  19:37:10o 282  19:42:03o 189 65  19:47:04* 112        ISS
I'm tempted to see whether the daylight pass peaking at 8:33 at 83 degrees is visible... I forgot that one. I did see the one just after 10pm though. I also, quite by chance, caught an Irridium flare at about 21:02 UTC.
I looked for the 8:33 one but saw nothing - the sky was too bright.  The one after 10pm I managed to image.
Rick,
Have you got the link to the website you are using for these charts?
I run them off using sattrack. They used to go onto the old website twice a week. I've yet to sort out the business of getting them into the new website; one of those round tuits I havn't yet got...
The old locations (which still get updated) are:
http://www.chocky.demon.co.uk/oas/predictions.txt - a bunch of visible(-ish) satellites
http://www.chocky.demon.co.uk/oas/predictiss.txt - the ISS predictions
http://www.chocky.demon.co.uk/oas/predictiridium.txt - Iridium satellites (the lot...)
http://www.chocky.demon.co.uk/oas/predictnoss.txt - NOSS pairs and triplets
All are based on the latest elements I can get at the time, and become increasingly inaccurate as elements become out-of-date...
If you know your own location, then www.heavens-above.com may give better results.
Bright passes (mag -2.0 and brighter) every single evening from Thur 25 Sept to Fri 3 October
More info at:
Or Rick's link at:
