NGC 2244 in Monoceros The Rosette Nebula
Started by Fay, Feb 10, 2008, 13:19:44
This was taken with SX MX7 , WO ZS66, Ha, cls filters 0.8 FR/Flattener.
Processed with Astroart, Maxim, PS CS.
L 18x300 secs RGB 5 x 300 secs each channel.
I kept my patience in check & stayed with one subject. I was pleased that my webcam was ok, as I have had problems. IT is the first image that I have processed on my own, although it has taken all day!!!! I am quite pleased wih it, so worthwhile.
Well done Fay,
Excellent image and it was worthwhile, another to add to your now long list. Have you thought about a Web-site like John,Chris and Mike,
could be an idea for another little project.
Speak to you soon.
ps  your batteries are here, I'll keep them in the car and the next time i'm passing I'll drop them in.
Thanks Tony.
Mike has set me one up I must get back to him to update it. Tony, to get that ISS going past mars would be fantastic. I won't be able to do it as my Canon soft ware is playing up.
See you soon about batteries, I have been charging my one up a lot!
Have you been away yet?
I always put the wrong camera name down. It should be SXV M7.
There's a lot of nice detail in that image.  Well done.
Do you know why the stars have a greenish tint?
My processing . I will correct it.
Thanks Mark
a bit psychedelic that is :)
I had a little go that one last night, dim, isn't it. You did a much better job than I did... Are you going to have a go at the Cone too, now John's laid down the gauntlet?
Well, for the first time in ages I have just put the 6" on & would like to try & remember K3, to do the Moon & Mars. If all goes well, I may try & get a few more of M81 & then go to M51. Knowing how things go, I probably won't get past the Moon bit!!
I do like the nebulae, they are interesting, nothing like thinking you have found it & seeing what you have got on the screen.
What about you, Ian?
yup. I liked the confirmation that I saw what I thought I saw in the eyepiece. Unfortunately, now I'm using an SLR lens I don't get to look through it any more but still the challenge remains.
I still like it when I tell the scope to point at an object and it appears on the screen in front of me. I just need to get 100% of kit working all at once and I'll be away :)
I'm afraid I've just about given up on visual observing in Sidcup. I'll get my visual kicks from the Lightbridge at DSC.
Well done Fay. Lovely image. Get that colour balance sorted out and it will be great.
Fay - why don't you post the L that you sent to me - That was brilliant - john
Thanks a lot Mike. I will put L on for you to look at
Thankyou Carole. I must admit, I was quite pleased with it.
