Author Topic: FAQ: How to crop images in the gallery  (Read 2416 times)
    • Faysastroimages
« on: Aug 19, 2007, 12:22:01 »
Rick, an afterthought, how do you crop?
  • Administrator
« Reply #1 on: Aug 19, 2007, 21:17:39 »
When you've selected the "Crop and Rotate" you are presented with the full-size image in a new window.
Check the "Enable clipping, apply to crop" tick box. A couple of corner markers will appear in top left and bottom right corners.
Click-and-drag the corner markers to frame the image the way you want it.
Then select an appropriate JPEG Output Quality, and click "Save picture".
"Save as thumbnail" doesn't do the brightest of jobs, so I advide not using it...
(... and I figure it's better to have done the cropping and framing and conversion to JPEG and so on on your own computer where you most likely have better tools for the job.)
