Solar Cycle 24
Started by Rick, Aug 09, 2007, 17:08:42
QuoteThe material belched from the sun during the Aug. 1 flare is not expected to cause any disturbances on Earth other than creating spectacular auroras. Auroras are created when charged particles are caught by Earth's magnetic field and interact with the atmosphere above the poles.
The Aug. 1 solar flare was a moderate C-class flare. The coronal mass ejection it set off created a strong so-called geomagnetic storm that lasted nearly 12 hours – enough time for auroras to spread from Europe to North America, NASA officials said in a statement.
Stronger solar storms could cause adverse impacts to space-based assets and technological infrastructure on Earth.
So much excitement over a relatively small event. What's the betting the next really big one will be ignored completely (until...)...
PhilB
Quote from: Rick on Aug 05, 2010, 23:15:59.......What's the betting the next really big one will be ignored completely (until...)...
...it takes out the National Grid   :o
You're probably right  :roll:
Irregular heartbeat of the Sun driven by double dynamo
A new model of the Sun's solar cycle is producing unprecedentedly accurate predictions of irregularities within the Sun's 11-year heartbeat. The model draws on dynamo effects in two layers of the Sun, one close to the surface and one deep within its convection zone. Predictions from the model suggest that solar activity will fall by 60 per cent during the 2030s to conditions last seen during the 'mini ice age' that began in 1645. Results will be presented today by Prof Valentina Zharkova at the National Astronomy Meeting in Llandudno.
It is 172 years since a scientist first spotted that the Sun's activity varies over a cycle lasting around 10 to 12 years. But every cycle is a little different and none of the models of causes to date have fully explained fluctuations. Many solar physicists have put the cause of the solar cycle down to a dynamo caused by convecting fluid deep within the Sun. Now, Zharkova and her colleagues have found that adding a second dynamo, close to the surface, completes the picture with surprising accuracy.
More: http://www.ras.org.uk/news-and-press/2680-irregular-heartbeat-of-the-sun-driven-by-double-dynamo
