ZS66 outing
Started by Rocket Pooch, Aug 06, 2007, 14:41:02
Ok, on Saturday I decided not to image, although the skies we're fantastic, so what I did instead is drove down just 10 miles north of Rye and did a couple of hours visual.  Wow it was dark, unlike Tuesnode you could not see a person 10 foot from you untill the moon came up, but you could still see the Ashford haze in the far distance.
With the ZS I managed to see the structure of M27 with a 26mm Skywatcher eyepiece as well as NGC 6830 & 6823, the ngc objects are about mag 7.
This little scope is fantastically portable and excellent for bright wide field images.
I also did a little double star splitting, I had a  Siebert Optics 7.3 mm star splitter eyepiece made for me (www.SiebertOptics.com) odd little eyepiece by at £50 its was a lot clearer and better at splitting doubles than my 5mm Skywatcher Eyepiece.  Alberio was well and trully split, and the two double doubles in Lyra we're easy as well.  I did not get much of a chance to do more than an hour because I needed some sleep, so off to be me went!
oops forgot to put this here http://www.carbonar.es/s33/Lyra/33_lyra_maps.html
