Jupiter: Turmoil from Below, Battering from Above
Started by Whitters, Jun 26, 2006, 21:33:57
The dark brown stripe of clouds on Jupiter that disappeared from view last year is reappearing.
Astronomers confirmed Wednesday (Nov. 24) that the gas giant's South Equatorial Belt (SEB), one of two distinctive dark stripes formed by the planet's cloud chemistry and winds, is coming back. They attributed the return of the view to a shift in Jupiter's cloud cover.
More:   SEB
Jupiter, the mythical god of sky and thunder, would certainly be pleased at all the changes afoot at his namesake planet. As the planet gets peppered continually with small space rocks, wide belts of the atmosphere are changing color, hotspots are vanishing and reappearing, and clouds are gathering over one part of Jupiter, while dissipating over another. The results were presented today by Glenn Orton, a senior research scientist at NASA's Jet Propulsion Laboratory, Pasadena, Calif., at the American Astronomical Society's Division for Planetary Sciences Meeting in Reno, Nev.
"The changes we're seeing in Jupiter are global in scale," Orton said. "We've seen some of these before, but never with modern instrumentation to clue us in on what's going on. Other changes haven't been seen in decades, and some regions have never been in the state they're appearing in now. At the same time, we've never seen so many things striking Jupiter. Right now, we're trying to figure out why this is all happening."
More: http://www.jpl.nasa.gov/news/news.php?release=2012-328
Jupiter's Red Spot is Likely a Sunburn, Not a Blush
The ruddy color of Jupiter's Great Red Spot is likely a product of simple chemicals being broken apart by sunlight in the planet's upper atmosphere, according to a new analysis of data from NASA's Cassini mission. The results contradict the other leading theory for the origin of the spot's striking color -- that the reddish chemicals come from beneath Jupiter's clouds.
The results are being presented this week by Kevin Baines, a Cassini team scientist based at NASA's Jet Propulsion Laboratory, Pasadena, California, at the American Astronomical Society's Division for Planetary Science Meeting in Tucson, Arizona.
Baines and JPL colleagues Bob Carlson and Tom Momary arrived at their conclusions using a combination of data from Cassini's December 2000 Jupiter flyby and laboratory experiments.
In the lab, the researchers blasted ammonia and acetylene gases -- chemicals known to exist on Jupiter -- with ultraviolet light, to simulate the sun's effects on these materials at the extreme heights of clouds in the Great Red Spot. This produced a reddish material, which the team compared to the Great Red Spot as observed by Cassini's Visible and Infrared Mapping Spectrometer (VIMS). They found that the light-scattering properties of their red concoction nicely matched a model of the Great Red Spot in which the red-colored material is confined to the uppermost reaches of the giant cyclone-like feature.
More: http://www.jpl.nasa.gov/news/news.php?feature=4372
Jupiter's Great Red Spot: A Swirling Mystery
The largest and most powerful hurricanes ever recorded on Earth spanned over 1,000 miles across with winds gusting up to around 200 mph. That's wide enough to stretch across nearly all U.S. states east of Texas. But even that kind of storm is dwarfed by the Great Red Spot, a gigantic storm in Jupiter. There, gigantic means twice as wide as Earth.
With tumultuous winds peaking at about 400 mph, the Great Red Spot has been swirling wildly over Jupiter's skies for the past 150 years—maybe even much longer than that. While people saw a big spot in Jupiter as early as they started stargazing through telescopes in the 1600s, it is still unclear whether they were looking at a different storm. Today, scientists know the Great Red Spot is there and it's been there for a while, but they still struggle to learn what causes its swirl of reddish hues.
More from NASA's Goddard Space Flight Centre
Jupiter Descending
If you did fall into Jupiter's atmosphere in a submarine, what would it actually look like? What would you see before you melted or burned up?
More: http://what-if.xkcd.com/139/  :)
