New Horizons: A mission to Pluto and the Kuiper Belt
Started by Ian, Jan 19, 2006, 20:48:15
Pluto certainly looks like it is going to have an interesting surface. I can't wait to see the close up images. Shame the craft won't be orbiting Pluto.
That is a shame I hadn't realise that would be a case.
Pluto is certainly an odd shape, which I think confirms they were right to classify it as a minor planet.
I think it might turn out to be spherical upon closer inspection and that the odd shape is due to images taken at low resolution plus dark and light patches across the surface.
New animations shows it is spherical with some huge contrast in light and dark across the surface.
VIDEO
Still doesn't look completely spherical to me, it has a lump protruding in one place which you can see as it rotates.
New Horizons Color Images Reveal Two Distinct Faces of Pluto, Series of Spots that Fascinate
New color images from NASA's New Horizons spacecraft show two very different faces of the mysterious dwarf planet, one with a series of intriguing spots along the equator that are evenly spaced. Each of the spots is about 300 miles in diameter, with a surface area that's roughly the size of the state of Missouri.
Scientists have yet to see anything quite like the dark spots; their presence has piqued the interest of the New Horizons science team, due to the remarkable consistency in their spacing and size. While the origin of the spots is a mystery for now, the answer may be revealed as the spacecraft continues its approach to the mysterious dwarf planet. "It's a real puzzle—we don't know what the spots are, and we can't wait to find out," said New Horizons principal investigator Alan Stern of the Southwest Research Institute, Boulder. "Also puzzling is the longstanding and dramatic difference in the colors and appearance of Pluto compared to its darker and grayer moon Charon."
New Horizons team members combined black-and-white images of Pluto and Charon from the spacecraft's Long-Range Reconnaissance Imager (LORRI) with lower-resolution color data from the Ralph instrument to produce these views. We see the planet and its largest moon in approximately true color, that is, the way they would appear if you were riding on the New Horizons spacecraft. About half of Pluto is imaged, which means features shown near the bottom of the dwarf planet are at approximately at the equatorial line.
More from NASA
New Horizons Team Responds to Spacecraft Anomaly
The New Horizons spacecraft experienced an anomaly the afternoon of July 4 that led to a loss of communication with Earth. Communication has since been reestablished and the spacecraft is healthy.
The mission operations center at the Johns Hopkins University Applied Physics Laboratory, Laurel, Maryland, lost contact with the unmanned spacecraft -- now 10 days from arrival at Pluto -- at 1:54 p.m. EDT, and regained communications with New Horizons at 3:15 p.m. EDT, through NASA's Deep Space Network.
More from NASA
Technical problem pauses Pluto probe's science operations
NASA's New Horizons space probe, 10 days from a one-shot encounter with enigmatic Pluto, stopped collecting science data Saturday after a technical problem interrupted the spacecraft's tightly-choreographed flight plan.
Engineers at the New Horizons control centre in Maryland lost contact with the distant spacecraft for nearly an hour-and-a-half Saturday. The controllers restored communications with New Horizons via NASA's Deep Space Network antennas at 1915 GMT, according to a status update posted on the mission's website.
Astronomy Now's article on the incident.
NASA's New Horizons Plans July 7 Return to Normal Science Operations
NASA's New Horizons mission is returning to normal science operations after a July 4 anomaly and remains on track for its July 14 flyby of Pluto.
The investigation into the anomaly that caused New Horizons to enter "safe mode" on July 4 has concluded that no hardware or software fault occurred on the spacecraft. The underlying cause of the incident was a hard-to-detect timing flaw in the spacecraft command sequence that occurred during an operation to prepare for the close flyby. No similar operations are planned for the remainder of the Pluto encounter.
More from NASA
(Hope it all works smoothly...)
Latest Images of Pluto from New Horizons
These are the most recent high-resolution views of Pluto sent by NASA's New Horizons spacecraft, including one showing the four mysterious dark spots on Pluto that have captured the imagination of the world. The Long Range Reconnaissance Imager (LORRI) obtained these three images between July 1 and 3 of 2015, prior to the July 4 anomaly that sent New Horizons into safe mode.
More: http://www.nasa.gov/feature/latest-images-of-pluto-from-new-horizons
Latest images from New Horizons courtest of Popular Science...
CLICK HERE
Pluto almost looks like it has clouds.
Pluto and Charon: New Horizons' Dynamic Duo
They're a fascinating pair: Two icy worlds, spinning around their common center of gravity like a pair of figure skaters clasping hands. Scientists believe they were shaped by a cosmic collision billions of years ago, and yet, in many ways, they seem more like strangers than siblings.
A high-contrast array of bright and dark features covers Pluto's surface, while on Charon, only a dark polar region interrupts a generally more uniform light gray terrain. The reddish materials that color Pluto are absent on Charon. Pluto has a significant atmosphere; Charon does not. On Pluto, exotic ices like frozen nitrogen, methane, and carbon monoxide have been found, while Charon's surface is made of frozen water and ammonia compounds. The interior of Pluto is mostly rock, while Charon contains equal measures of rock and water ice.
More: http://www.nasa.gov/feature/pluto-and-charon-new-horizons-dynamic-duo
NASA Missions Have Their Eyes Peeled on Pluto
What's icy, has "wobbly" potato-shaped moons, and is the world's best-known dwarf planet? The answer is Pluto, and NASA's New Horizons is speeding towards the edge of our solar system for a July 14 flyby. It won't be making observations alone; NASA's fleet of observatories will be busy gathering data before and after to help piece together what we know about Pluto, and what features New Horizons data might help explain.
"NASA is aiming some of our most powerful space observatories at Pluto," said Paul Hertz, Astrophysics Division Director at NASA Headquarters, Washington. "With their unique capabilities combined, we will have a multi-faceted view of the Pluto system complementary to New Horizons data."
Right around New Horizons' closest approach to Pluto, Cassini will take an image of the dwarf planet from its station in orbit around Saturn. Although Cassini is the closest spacecraft to New Horizons' distant location, the image of Pluto will be but a faint dot on a field of stars. Even so, the image will provide a scientific measurement of Pluto from a different vantage point that will complement data collected by New Horizons.
More: http://www.jpl.nasa.gov/news/news.php?feature=4656
New Image of Pluto: 'Houston, We Have Geology'
It began as a point of light. Then, it evolved into a fuzzy orb. Now – in its latest portrait from NASA's New Horizons spacecraft – Pluto is being revealed as an intriguing new world with distinct surface features, including an immense dark band known as the "whale."
As the newest black and white image from New Horizons' Long Range Reconnaissance Imager (LORRI) appeared on the morning of July 10, members of the science team reacted with joy and delight, seeing Pluto as never before. There will no doubt be many similar moments to come. New images and data are being gathered each day as New Horizons speeds closer to a July 14 flyby of Pluto, following a journey of three billion miles.
"We're close enough now that we're just starting to see Pluto's geology," said New Horizons program scientist Curt Niebur, NASA Headquarters in Washington, who's keenly interested in the gray area just above the whale's "tail" feature. "It's a unique transition region with a lot of dynamic processes interacting, which makes it of particular scientific interest."
More: http://www.nasa.gov/feature/new-image-of-pluto-houston-we-have-geology
New Horizons' Last Portrait of Pluto's Puzzling Spots
Three billion miles from Earth and just two and a half million miles from Pluto, NASA's New Horizons spacecraft has taken its best image of four dark spots that continue to captivate.
The spots appear on the side of Pluto that always faces its largest moon, Charon—the face that will be invisible to New Horizons when the spacecraft makes its close flyby the morning of July 14. New Horizons principal investigator Alan Stern of the Southwest Research Institute, Boulder, Colorado, describes this image as "the last, best look that anyone will have of Pluto's far side for decades to come."
The spots are connected to a dark belt that circles Pluto's equatorial region. What continues to pique the interest of scientists is their similar size and even spacing. "It's weird that they're spaced so regularly," says New Horizons program scientist Curt Niebur at NASA Headquarters in Washington.  Jeff Moore of NASA's Ames Research Center, Mountain View, California, is equally intrigued. "We can't tell whether they're plateaus or plains, or whether they're brightness variations on a completely smooth surface."
More: http://www.nasa.gov/image-feature/new-horizons-last-portrait-of-pluto-s-puzzling-spots
