M81 and M82
Started by JohnH, Mar 19, 2025, 13:12:46
JohnH
It is clearly Bode season. This is my final processing (probably) of M81/82 collected 22nd Feb to 2nd March. [he background might be too dark though]
L comprises HaO and a contribution from RGB
Chrom comprises HaRGB
Total imaging time: 7 hours
Sharpstar 15028 HNT
ZWO ASI1600MM Pro at 10C
iOptron CEM 25P
ZWO HaO, Ha, R, G and B filters
ZWO ASIAir Pro
Processed in Pixinsight, finished in Affinity Photo 2
Regards,
Is this a reprocess John as I already have M81 and M82 from you, same FOV.
JohnH
Quote from: Carole on Mar 19, 2025, 18:15:14Is this a reprocess John as I already have M81 and M82 from you, same FOV.
Hi Carole,
It's my third attempt at imaging M81/82. I have added some more data to an image that I put on WhatsApp and reprocessed it. It is probably because my setup uses "plate solving" to locate targets and so ends up with similar FOVs if I repeat a target.
OK, not sure which one to put on Members Images.  I'll WA you the one I have already.
