Author Topic: M42  (Read 105 times)
JohnH and 1 Guest are viewing this topic.
  • Mr October
  • Galaxy Class
    • AstroManche
M42
« on: Feb 18, 2021, 10:22:44 »
I am a bit mystified by the flatness of the Ha on the right of the picture.
137x60s 2h17m Gain120 Offset 4 Temp-5C 10xDark, 10xFlat, 10xDarkFlat Processed in PixInsight using Weighted Batch Pre-Processing v2 (as easy as DSS!) and EZProcessing scripts with a tweak using Curves Transformation.
Image date, time and location:   2021-02-10, 20:22-00:17, Manche, France
Telescope aperture and focal ratio:   Sharpstar 61EDPH F4
Camera and filters used:   ZWO ASI294 MC Pro, Optolong L-eNhance Ha, Hb, OIII filter
Processing applied:   PixInsight (WBPP2, EZ, CT)
¯\_(ツ)_/¯ (Gallic shrug :))
    • Carole's images
Re: M42
« Reply #1 on: Feb 19, 2021, 11:04:32 »
That's come our really well Duncan.
Very nicely processed except I think the brighter part of the nebula is a bit bright and obscuring detail, did you take any shorter subs to combine?
Quote
As regards your comment above, I had a feeling that Ha was a bit lacking on that side of the nebula and did a search and found this one below.  Whilst there is Ha on that side, it's no-where near as bold and detailed as on the left side.
https://www.astrobin.com/340230/?nc=user
  • Mr October
  • Galaxy Class
    • AstroManche
Re: M42
« Reply #2 on: Feb 19, 2021, 11:16:31 »
Thanks Carole. Noted about the Ha.
I used a PI function called Masked Stretch, probably need to ratchet it up. The well depth of my asi294 and so it's dynamic range means at 60s I can see the trapezium stars on my main pc. I think conversion to jpeg has lessened the range somewhat, 32 to 8 bit🙁
  • Galaxy Class
Re: M42
« Reply #3 on: Feb 19, 2021, 17:05:46 »
Nice one Duncan and very pleasing colours, pretty good stars in all four corners - I presume this is using the reducer ?
Are you autofocusing yet or is this with a Baht ?
JPEGs are always a PITA when it come to dynamic range.
  • Mr October
  • Galaxy Class
    • AstroManche
Re: M42
« Reply #4 on: Feb 19, 2021, 18:39:50 »
Thanks Robert. I'm using PhotometricColourCalibration in narrowband mode with the passbands entered.
It is using to the flattener which makes it a 5 element apo. The focus is automatic but I think I need to tighten the grub screws and glue them as it's gone sloppy! The autofocus often fails but it's pretty  good anyway. More tweaking.
  • Star Class
    • Astrobin
Re: M42
« Reply #5 on: Feb 20, 2021, 17:20:47 »
That's a cracking shot Duncan.  I love the nebulosity and framing.
  • Mr October
  • Galaxy Class
    • AstroManche
Re: M42
« Reply #6 on: Feb 21, 2021, 13:59:23 »
Thanks Roberto, high praise much appreciated.
