Author Topic: M31 reprocessed  (Read 85 times)
JohnH
  • Nebula Class
  • Unknown Entity
M31 reprocessed
« on: Nov 20, 2020, 18:33:32 »
This is a reprocessed version of M31, all data gathered on 3rd November.
ASI1600MM Pro.
Sharpstar 15028 HNT
LHaRGB
As an experiment I have thrown Pixinsight at it. To me, I am astonished by the amount of detail I have captured even though it is still fairly noisy and I suspect that some of the nebulosity is processing artefact.
To be fair:
1) There was a 95% illuminated Moon about 60 degrees away from M31,
2) there was a lot of blotching in the background which I have struggled to get rid of, and
2) I still do not really know what I am doing!
However, I do like to think I am getting better.
  • Star Class
Re: M31 reprocessed
« Reply #1 on: Nov 25, 2020, 10:24:19 »
Excellent scale and a huge amount of detail there John.
Very well done getting to grips with PI (something I've not managed).
Speaking as a non-expert; I suspect the sharpening has overcooked some of the stars making them a bit hollow, and there is a distinct fabric texture around the M32 and a sort of curdled look to some of the nebulosity as if it's been over sharpened. Is it possible to back off the deconvolution a few notches?
But the detail and colour you've captured makes a very pleasing image.  Well done.
Noel
  • Star Class
    • Astrobin
Re: M31 reprocessed
« Reply #2 on: Nov 25, 2020, 11:31:14 »
Looking very good John!  The dust lanes you have managed to extract look amazing  8)
JohnH
  • Nebula Class
  • Unknown Entity
Re: M31 reprocessed
« Reply #3 on: Nov 26, 2020, 10:03:07 »
Noel and Roberto, thanks for the encouragement.
I really did throw the Pixinsight equivalent of the kitchen sink at the image to see what could be done and so I am not surprised it looks a bit overdone.
From further reading I suspect that I have been taken in by the "Focal Ratio Myth". I had been working on the basis that f2.8 meant that I needed less time per channel but it really means more but shorter exposures. So my L filter was 100 x 20 second exposures and benefited enormously when turned into a "Superluminance" by adding 30 x 40 second reds, 20 x 90 second greens, 20 x 120 second blues and 10 x 300 second Ha. However, the colour filter frames should have been a much longer total exposure.
Also, the exposure times of the colour frames was arbitrary. I have now taken the transmission curves of the filters and the Qe curve of the camera and done a back of the envelope approximation which suggests that the overall transmission across the wavelength range of the RGB filters is consistent.
It is all part of the learning curve.
    • Carole's images
Re: M31 reprocessed
« Reply #4 on: Nov 26, 2020, 11:19:03 »
Now that is looking great, well done.
Also well done for mastering Pixinsight.
