NGC 6820 nebula and NGC 6823 open cluster in Vulpecula
Started by The Thing, Aug 18, 2020, 08:35:44
NGC 6820 is a small reflection nebula near the open cluster NGC 6823 in Vulpecula. The reflection nebula and cluster are embedded in a large faint emission nebula called Sh 2-86. The whole area of nebulosity is often referred to as NGC 6820
7h20m  88x300s Gain 120 Offset 4 Temp -15c 10xDark, Flat, DarkFlat. taken just after full moon, remarkable as I couldn't have imaged at all then without the filter. Needs more data of course, preferably on a dark night! Couldn't coax out any more whatever I stacked/processed this in, tried DSS/PI/ASTAP/Darktable/GIMP. I know there are very iffy stars in one corner...
Image date, time and location: 2020-08-04,06 Manche France
Telescope aperture and focal ratio: TS1506UNC f4, TS-Optics GPU superflat 2" Coma Correktor for Newtonian telescopes, 4-element
Camera and filters used: ZWO ASI296 MC Pro, Optolong 2" L-eNhance dual-band Nebula Filter
Processing applied: ASTAP, DarkTable
Looking good, plenty of both bands coming through.  Colour a little subdued for you I think?
Noel
This one was a bit odd. 7 hours of data should have produced a stonking image despite a lot of moon on the nights but not so. Must do this object on a properly crisp dark night...
It's quite a faint target Duncan, especially the Oiii.
Excellent image and framing!  8) This one is on my to do list - for next year.
Lovely result and it's a great field of view.  But I wonder if there is sufficient OIII for the L-eNhance filter to do it justice.
Thanks Roberto and Mark. I might try adding OSC RGB if/when I attempt this again. I'll put it in the diary for next year.
