Shooting Star or....
Started by ApophisAstros, May 07, 2020, 10:54:09
x
Quote from: Apophis
Last nights highlight
Seems to be a Satelite and after a while it burns up so presumably a Meteor skimming the Earth and being pulled in then burning up.
Anyone got any idea on this?
I'm guessing it's an aircraft which develops a contrail.
I agree with Mark; it seems very dim in the dark part of the sky, but then becomes brighter as if it's being illuminated from below (rather than glowing).
Noel
Quote from: MarkS on May 07, 2020, 13:57:46
Quote from: Apophis
##Thanks Mark,Noel.
Would it have taken 2 mins 43 secs to go that short distance,and the absence of lights flashing on/off.??But you may be right,most plausable so far.
Had a thought, Space Debris as the contrail of an aircraft would have stayed for a bit?
It's been very dry. The few aircraft at high(-ish) altitude I'm seeing here (near the top of the Bristol Channel) have hardly any contrail during the day.
Quote from: Rick on May 07, 2020, 18:45:23
This was during DSD though and why was the contrail not continuous from start to finish like it usually is.
Quote from: Apophis on May 07, 2020, 19:27:36
We often get contrails that appear and disappear as the plane flies over, usually at around 30,000 ft here, there must be varying air pockets that the plane is flying through right on the cusp of trail/no trail conditions. 'Triple point of water' comes into my head at random :} Physics lessons were a long long time ago.
If a plane's flying close to an atmospheric boundary (like the troposphere/stratosphere level) and one air-mass is relatively more humid than the other, and the plane passes alternately through one and then the other, a contrail may appear like a line of dashes. Or a plane that's climbng or descending may start (or stop) producing a contrail as it passes from one air-mass into another with very different relative humidity or temperature. Boundary zones are seldom simple.
(Your video's on FB, so I've not been able to watch it, so I'm guessing from others' descriptions.)
Quote from: Rick on May 08, 2020, 18:17:47
Its public so everyone should be able to view.
Quote from: Apophis on May 08, 2020, 20:02:25Its public so everyone should be able to view.
I get a "Something went wrong" error. It won't elaborate further as to what than "something" might be.
Might be your settings as everyone else watches it fine.
MarkH
#12
FWIW I would say that is something entering the atmosphere and burning up. The reason I say that is because the trail follows a particular pattern. The trail starts quite dimly and then intermittently increases until all the matter is burned away when it suddenly disappears. Have a look at the footage of the famous Russian meteor strike and make a comparison.
Mark.
P.S. The fact that the "tail" keeps up with the head would also suggest this as contrails tend to last a few seconds at minimum and normally a few minutes.
#13
Seems Firefox took a dislike to the video. Safari managed to play it (after I told FB to leave off trying to make me login about sixty times, and it only let me view it a few times before telling me "content no longer available"...)
How long is the event? If it plays in "real time" (or therabouts, given the field of view) then I'd say you have a meteor/fireball. If it's playing more than about ten times "real time" speed then I'd suspect an aircraft. Looking closely at individual frames may help.
If it's a piece of man-made space junk then you should be able to find predictions and reports of its decay. There's nothing for that date on https://aerospace.org/reentries (but it seems to list major objects only). http://www.satview.org/spacejunk.php has a more comprehensive list, but again doesn't show anything close to that date.
Places to look for reports of fireballs over the UK include:
https://ukmeteornetwork.co.uk/fireballs/ (( dead link 2023/11/23 ))
https://www.popastro.com/main_spa1/meteor/fireball-sightings/
https://britastro.org/section_front/19
#14
Quote from: Rick on May 09, 2020, 11:22:12How long is the event? If it plays in "real time" (or therabouts, given the field of view) then I'd say you have a meteor/fireball. If it's playing more than about ten times "real time" speed then I'd suspect an aircraft. Looking closely at individual frames may help.
There is a timecode top left.
