Solar Disc from 23 April
Started by ApophisAstros, Apr 25, 2020, 00:41:18
3000 frames at 2.2 fps
Processed with PIPP , Adobe Photoshop CS2.
Earth top left for comparison size.
Good outcome Roger and nicely coloured.
Thanks Carole and Roberto , i have since had advice about that bright area in the middle and need to do a Flat field the next time i use the Solar Scope, i.E. cover the end of the scope at the begining with a plastic bag and in SharpCap there is a way of automizing it where it automatically applies the Flat when you capture.
