M42 and Horsehead Nebulae FOV Test
Started by Carole, Apr 22, 2020, 20:20:56
I took this last month more as a test of FOV but only got very little data before it sank behind the trees.
Wasn't going to bother to process it, but being at a loose end during the Coronavirus lockdown I decided to "give it a go".
Atik460EX and Samyang 135mm F2 lens.
Ha 600secs x 3
RGB 2 x 100secs each (unbinned as anything binned blew out the sensor with this fast lens).
So total imaging time 35 minutes.
Larger fov:
http://gallery.orpington-astronomy.org.uk/albums/userpics/10047/M42_-_HH_HaRGB.png
Slightly deeper colour:
Thanks Roger.  I never expected to get an image out of it.
Very good Carole; well worth processing.
Look at all that nebulosity.
Noel
You must be glad you decided to process it; it looks great!  That lens is working really well for you; can't wait to see what you do with it over the summer.
Thanks Roberto.  Yes I am very pleased with it, but there's not much suitable for wide field ATM.
