Venus showing crescent 31 March 2020 19:20CET, Manche, France
Started by The Thing, Apr 05, 2020, 13:46:08
Full size and 4x enlargement of the Planet of Lurve. RGB, UV/IR filter so not much you could call real detail. PlanetarySystemStacker did most of the work and Registax was used to align the RGB pixels as PST doesn't do that. GIMP was used just to create the composite image.
FireCapture v2.6 Settings
Observer=Duncan Evenden
Location=Manche, France
Scope=LX90 8" UHTC, X2 ED Barlow, PierroAstro ADC
Camera=ZWO ASI294MC Pro
Filter=L
Profile=Venus
Diameter=25.46"
Magnitude=-4.40
FocalLength=1800mm (F/8)
Resolution=0.53"
Filename=2020-03-31-1920_4-DE-L-Ven.ser
Date=310320
Start=192020.986
Mid=192029.929
End=192038.872
Start(UT)=192020.986
Mid(UT)=192029.929
End(UT)=192038.872
Duration=17.886s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT +1h
Frames captured=3000
File type=SER
Binning=no
Bit depth=8bit
Debayer=yes
DebayerAlgorithm=Bilinear
BayerPattern=RG
ROI=264x238
ROI(Offset)=1924x1329
FPS (avg.)=167
Shutter=2.723ms
Gain=50 (8%)
HighSpeed=on
Gamma=50 (off)
AutoGain=off
FPS=100 (off)
WBlue=90 (off)
Brightness=30 (off)
USBTraffic=79 (off)
TargetTemp=-5
SoftwareGain=10 (off)
AutoHisto=75
AutoExposure=off
WRed=60 (off)
Histogramm(min)=0
Histogramm(max)=0
Histogramm=0%
Noise(avg.deviation)=n/a
Limit=3000 Frames
Sensor temperature=-4.9°C
Target=Venus, Date: 310320, Time: 192029 UT, Mag: -4.40, Dia: 25.46, Res: 0.53, Az: 269.21, Alt: 31.76, Phase: 0.47, CM: , Camera: ZWO ASI294MC Pro, Scope: LX90 8" UHTC, X2 ED Barlow, PierroAstro ADC, FL: 1800mm, F-ratio: 8
Very good Duncan
Is that a whisp of detail on the surface?
Noel
Quote from: NoelC on Apr 05, 2020, 15:18:54
Very good Duncan
Noel
Ta much. Or a will o' the wisp. Probably a stacking/resizing effect but maybe not.
