Coma Cluster - Abell 1656 from Petts Wood
Started by Roberto, Mar 20, 2020, 10:19:38
Another one completed over the last couple of months because of poor weather.
Poor transparency meant colour for galaxies and stars was muted but aplenty for the background!  :!
This is an amazing area of the sky. The count of galaxies in the annotated image is 570! Maybe more stars than galaxies.
Enjoy!  https://www.astrobin.com/8kzq9w/C/?nc=user
Annotated:
Another excellent image.  Well done!
Hugh
Hi Roberto
These photographs are so illustrative of the hidden galaxies (especially in the annotated) and, if you don't mind, I would like to include them in my ''Space is BIG!' talk?
They will be attributed to you, of course!
Best
Hugh
Mark, many thanks!
Hugh, of course - the scale of the cluster is mind-boggling.  And to think this is only a section of the super-cluster!  If you need a higher resolution image or one where the labels don't intrude as much, please let me know and I'll generate it.
Another excellent image, quite a result from Petts Wood !
Higher resolution did you say - yes please
Lovely image Roberto.  Well done.
Hugh
Thank you Roberto ~ the annotated is the one that gives the wow! factor ~ I can overlay one on the other.  It will give a good example of the vast number of galaxies there are and fits in nicely with that part of the talk.
Hugh
