Author Topic: Observatory Power supply ?  (Read 1706 times)
Apophis
  • Cluster Class
  • Solar , Deepsky
Re: Observatory Power supply ?
« Reply #15 on: Nov 02, 2019, 18:23:57 »
  • Star Class
« Reply #16 on: Nov 03, 2019, 10:38:46 »
Thanks Duncan
I'm interested you put a scope on the output of a step down converter and it was clean.  Have been using a 12-5V converters for a pi and for a usb powered hub quite successfully but wasn't sure if they were clean. Haven't got a current meter on the supply; so no idea how close to its maximum it's running.  But you know how it is; you just keep slapping another camera or focuser on the system until suddenly you start losing connection when it slews.
What's the ripple on the brick like?
Noel
  • Mr October
  • Galaxy Class
    • AstroManche
« Reply #17 on: Nov 03, 2019, 10:47:28 »
The brick is not bad, some of my others e.g. the on that came with the 12v usb3 hub are very notchy. I want to get a higher voltage brick as that will keep the input to the stepdown converter steadier as loads vary. I have a 19v one also Tosh, but need to use the oscilloscope to check the output.
¯\_(ツ)_/¯ (Gallic shrug :))
