NGC6960 Western Veil 2018-07-15
Started by The Thing, Jul 27, 2018, 21:27:41
I've been wrestling with processing this trying to knock back the stars and bring out the nebulosity, I hope it's not too leery.
42 x 300s at unity gain (120) and -15c.
Image date, time and location:        2018-07-15 00:00 UTC Manche, France
Telescope aperture and focal ratio:   TS1506UNC f4, TS Komakorr
Camera and filters used:              ZWO ASI294MC Pro, UV filter
Processing applied:                   PixInsight, Gimp 2.9
Excellent image!
I know what you mean about star reduction.  Imaging this area in RGB tends to make the stars bloaty when it is stretched enough to show the nebulosity.
I particularly like the area of dust above the Witches Broom because it doesn't appear in many images - I think most people accidentally remove it during background extraction.
Great FOV including Pickerings triangle which I find more difficult to process than the East and Western veils.
I thought the colour looked a bit washed out so I took it into PS to see if it could be enhanced and found that the image is actually clipped though was surprised as the image doesn't look clipped.
Anyway regardless, it's a fine image but for my taste I prefer slightly stronger colours.
Good stuff.
Hi Carole, thanks for the feedback. If there isn't enough colour maybe you need to adjust you monitor! Looks pretty vivid to me.
Thanks Mark, I may need a uv/ir filter to reduce bloat, or less beer. At the moment my setup is unfiltered. I have a Baader Neodymnium 2" I could use which would do the job but may alter the colour balance a bit. Unless I can wangle my uv/ir clip filter into the imaging train somehow.
QuoteHi Carole, thanks for the feedback. If there isn't enough colour maybe you need to adjust you monitor! Looks pretty vivid to me.
Vivid? Seriously?  Well I will take a look on one of my laptops and see if it is any different on there.
Quote from: The Thing
It's not looking vivid to me either.  I would describe it as subdued.
#7
i've got a topnotch laptop, and it does look washed out by stars , hard to see the detail.but good FOV .At gain of 120 in sql reading of 21 ish the recommended exposure time is 1.7 minute subs with my f6 refractor. Have you tried much shorter exposures.
In skies like Cairds DSC for darker skies i will try gain 50 and 4 minute subs and still be shot noise limited.
Quote from: MarkS on Jul 28, 2018, 23:45:51
I'll up the colour and recalibrate my monitor. But it still looks vivid on my phone and kindle...
Hi Roger
Sharpcaps chip characterisation function recommended 8.2s subs at gain 115 (120 is unity gain on this camera) but 1600 of them! I did a test of 1000 subs but have only tried a quick stack of 249 which seems to be DSS limit. The results were very good so I will go down this route in future. I need to try it on pixinsight when I've got a few hours.
Here's a brighter version. I love the GIMP 2.10, I think I've managed to knock back the stars a bit as well. BTW the full size image is half original size.
Ah, much better colour Duncan.
What method are you using to try to shrink the stars, I have a couple of methods for photoshop if you are interested?
On my monitor it looks horrendously lurid, and I've recalibrated with my Spyder5 and DisplayCAL(free) this morning so that is not a factor.
For the stars I'm using Pixinsight's MorphologicalTransformation [sic] works well if you get the settings right :! like most things. I may need to do a couple of iterations to shrink stars more. Also I am getting to grips with StarMask and RangeSelection for brightness masks. Robert has suggested shorter subs and I know he's right as the images I've done at 120s and 30s as well as the 8.2s ones mentioned below have much smaller stars. The temptation of longer subs is that they show a nice low noise image on the capture program preview when stretched. Clear skies at the end of the week so more chance to experiment with the ASI294.
I have checked my monitor calibration as well and it is fine, so not sure what is going on.
I know what you mean about the shorter subs having smaller stars, I get the same between using the RGB filters with shorter subs and the Luminance stars being a fair bit larger as the subs are longer and the lum filter probably lets in more light anyway.
Ideally you want the extra nebulosity with the longer subs but the smaller stars with the shorter subs, its a balancing act.
I wonder if you could do some of each, and try to combine in some sort of post-processing magic.
Quote from: Carole on Jul 29, 2018, 13:04:25
Basically that's what Robert has suggested :) So I'll set Pixinsight off stacking 1000 x 8.2s subs this afternoon.
