Author Topic: Advice from Gurus please  (Read 128 times)
    • Carole's images
« on: Nov 01, 2017, 22:17:48 »
Can a chip deteriorate?
My QHY5 has developed an area bottom right - but a large area bottom right stretching from middle bottom to 1/3 up on the right where it is quite patchy and blotched.  I don't think I could see any stars in it.  I should have taken a screen shot and if it's like it next time I will do so.
« Last Edit: Nov 01, 2017, 22:25:25 by Carole »
Re: Advice from Gurus please
« Reply #1 on: Nov 01, 2017, 22:33:06 »
I guess a chip can deteriorate electronically.  On the other hand it could have a physical cause. What does the sensor look like?  Is there dew?  Is there fungus growing on it?  Is there some other kind of deterioration?
    • Carole's images
« Reply #2 on: Nov 02, 2017, 08:32:03 »
I must admit I have not had a look at it as yet as it's still in the van, but will take a look later on.
    • Carole's images
« Reply #3 on: Nov 02, 2017, 12:18:31 »
Aha, Sorted.   I took the camera off the finderscope and found that the foam inside the camera had slipped and was in an even worse position than when I was last imaging.
Why is this foam inside the cameras, and can it been removed?  I am sure it would be easy to do with some tweezers.
« Last Edit: Nov 02, 2017, 13:07:06 by Carole »
