Alignment ?
Started by ApophisAstros, May 12, 2017, 16:34:51
Now I'm computer controlled I wondered what Everyone's favourite alignment techniques were,I have read about drift alignment ,
Kit - Sky-Watcher EVOSTAR-120ED DS-PRO (OTA) 120mm (4.75î) f/900 ED Apochromatic Refractor Telescope Plus .85x Focal Reducer
Sky-Watcher EQ6-R PRO SynScan™ GoTo Equatorial Mount
MarkH
#1
Hi Roger, I use an astro engineering  polar mate with my Meade wedge and it is very quick and accurate. It may be something you could adapt for the skywatcher.
Roger, you are using Polemaster, I don't think you need to do drift aligning as well.
Roy
Hi Roger,
Are you referring to 'Polar Alignment' specifically, or alignment in general?
Roy
Alignment in general 1,2 or 3 stars. since I posted I've sort of decided to use plate solving. There's a program that feeds the coordinates to the scope from the plate solving results.
Ah, your mention of Drift align confused me as that is concerned with polar alignment,
With EQMod which I haven't used for a while, but I think most people find just syncing on one star close to your chosen target is good enough for alignment, and I must admit it worked just fine when I used that method.
Hi roger
I use my finderguider and Sharpcap 2.9. Very easy with live feedback as you adjust the az and alt. Just like the QHY polaralign gadget but essentially free. Very accurate, I got my eq6 down to 0.5 arcmin off the NCP in about 5 minutes. Would have been quicker if the mount pa adjustment bolts etc was better made!
Duncan
