Two Clear Nights!!!!!
Started by ApophisAstros, May 08, 2017, 10:52:03
Looks like the first two clear nights in ages in Worthing ,hope it works out gonna try for Bodes Galaxy and Cigar nebula in one if i`ve got the FOV ,
FOV should be fine Roger.  If you're guiding is OK, then do 300sec subs @ 800 ISO.
Definitely a good night for a practice run.
The full moon means it will be difficult to capture faint objects such as galaxies so try a globular cluster instead.
P.S.  You'll soon discover that most of the clear nights are around the time of the full moon.
