Jupiter, GRS and Io Date: 110317, Time: 003239 UT
Started by The Thing, Mar 12, 2017, 15:37:55
Been practising as Jupiter is getting close to opposition, shame the sky has been so murky and seeing not so good. I'm hoping it will be better around 7 April. Shine up your Barlows!
FireCapture v2.5 Settings
Observer=Duncan Evenden
Location=Manche, France
Scope=LX90 8" UHTC, X2 ED Barlow, PierroAstro ADC, no filters at all.
Camera=QHY5LII-C
Filter=RGB
Profile=Jupiter
Diameter=42.99"
Magnitude=-2.38
CMI=336.6° CMII=287.8° CMIII=39.6° (during mid of capture)
FocalLength=4300mm
Resolution=0.18"
Filename=2017-03-11-0032_6-DE-RGB.ser
Date=110317
Start=003211.897
Mid=003239.915
End=003307.934
Start(UT)=003211.897
Mid(UT)=003239.915
End(UT)=003307.934
Duration=56.037s
Date_format=ddMMyy
Time_format=HHmmss
LT=UT +1h
Frames captured=3000
File type=SER
Binning=no
Bit depth=8bit
Debayer=yes
DebayerAlgorithm=HQLinear
BayerPattern=GR
ROI=400x400
ROI(Offset)=432x192
FPS (avg.)=53
Shutter=15.22ms
Gain=52 (52%)
Gamma=1 (off)
USBTraffic=27
AutoHisto=75
HighSpeed=on
Brightness=0 (off)
SoftwareGain=10 (off)
WBlue=75
WRed=75
Histogramm(min)=0
Histogramm(max)=194
Histogramm=76%
Noise(avg.deviation)=n/a
Limit=3000 Frames
MarkH
julian
Great image Duncan!  You have a good amount of detail in there.
We're plagued with cloud here and I still haven't have a chance to try out my GPCam2 IMX224 :(
Some great detail there Duncan.
It looks a little out of focus, is that because of the seeing?  I always find focus difficult with planetary imaging, in fact I have pretty much given up on planetary imaging as I find it so difficult, possibly because I don;t have the right kit in the first place, but you're doing really well.
Quote from: Carole on Mar 13, 2017, 09:13:26
Thanks Carole, Mark, Julian and John.
It was focused using a nearby star and Bahtinov mask, but the bad transparency and seeing (the jet stream is coming right over us north-southish at the moment) prevented a sharp image being produced. I hope for better conditions next time there is some clear sky, early mornings tend to be better as well.
looks good to me Duncan, at least you are keeping in practice!!!!
Thanks Fay. Are you going to have a go at Jupiter with your LX90 8" ACF?
