M42 / Horsehead, 16x600 QSI 583, 5nm Astrodon filter, Leitz 180mm at F4 190116
Started by Fay, Jan 21, 2016, 14:02:27
looks good Fay - lovely wide FOV - like you said maybe lacking a little bit of contrast due to the moon - loads of dusty stuff though.. John
yes thanks John. the Moon was right above it, but I thought I would see what happened. would have tried something else if moon had not been there, like Barnards loop
Looks really great Fay.
I did the same image on Tuesday night using a 200mm lens on the DSLR.  No-where near as good as this though.
That's a very nice widefield Fay.
It's good to see you getting out again.
I like that Fay. Is it my imagination or is this part of the sky getting gasier?
Well done Fay!
It's great to see an image from you again.  It's a fine image, especially given the nearby moon.
I've just been comparing your H-alpha with the redder dusty bits in my recent Orion image - they match up quite nicely :)
Gasier Duncan?
Thanks mark and robert. I have to make use of my extended sky view!
