DSLR to telescope
Started by Kenny, Jan 23, 2015, 21:28:19
Kenny
I'm looking into what 'fittings' I would need to connect my Canon 450D to a telescope, any telescope, for example 8" Dob, 6" Newt or the OAS Coronado.
I quote from Carole's website:
QuoteYou will also need some means of attaching your DSLR to your telescope.  You will need a T Ring (which fixes to the DSLR) and a T adapter which has a 2" nosepiece to fit into the telescope.  You will get better results if you use a flattener instead of a T adapter, and these are designed for specific telescopes, they flatten the field and the distance from sensor to point of entry to drawtube is vital to getting a nice flat field and nicely shaped stars into all the corners.
I only vaguely understand this, not enough to make a purchase, and don't know whether / why 2" is required rather than 1.25".
Grateful for your words of wisdom.
MarkH
Kenny most scopes have a 2" threaded connection point for accessories which is a standard thread. If you take your slr to somewhere like telescope house they stock "T" mount tubes, just make sure it fits your slr and its all you need.
Kenny, the DSLR will require a 2" nose piece otherwise you will get a tunnel vision effect.
Kenny
Thanks. The Dob and Newt support 1.25" and 2" but I don't think the Coronado does.
MarkH
My lx 90 has a 2" connector then an adaptor down to a 1 1/4" diagonal.
With the Coronado you will have to use a step down adapter if that's the case, not 100% ideal.
Having said that I tried to image with a DSLR and the society Coronado once and it didn't produce anything except a bright red blob.  You'd be much better using a webcam with the Coronado.  They say a mono camera is actually best for solar, you can re-colorize it afterwards.
Quote from: MarkH on Jan 23, 2015, 22:46:11
The thread on the back of an SCT type scope is not 2" filter type thread, it is 24tpi. But it is a 'standard' for the back of small to mid size SCTs so getting adaptors for t-mounts, diagonals and 2" push fittings is easy. It's a bit of a minefield and you end up with a large collection of this-to-that adaptors!
This is informative...
http://www.iceinspace.com.au/forum/archive/index.php/t-70937.html
Quote from: Carole on Jan 24, 2015, 09:33:00
I think you need some sort of extension tube to obtain focus with a camera on a Coronado. hence why you only got a red blob.
Quote from: Kenny on Jan 23, 2015, 22:39:18
For your DSLR you will need a DSLR to t-thread adaptor and a t-mount to 1.25" or 2" (if both scopes support 2" EPs) adaptor. You probably have a 1.25" to 2" eyepiece adaptor.
